[GRASSLIST:4417] Re: v.to.sites error
Radim Blazek blazek at itc.it
Mon Sep 27 04:14:29 EDT 2004
On Friday 24 September 2004 20:16, Maciek Sieczka wrote:
> Hi!
> It seems that v.to.sites fails to translate some points near the nodes.
> Ater doing as follows:
> GRASS:~ > v.to.sites -a -i input=rzezba output=site_rzezba dmax=1
>    v.to.sites:
> Number of vector nodes = 138
> Number of sites generated = 162789
> [Raster MASK present]
> I get a result a piece of which you can see on the vtosites.png, where:
> -RED is the input vector file "rzezba" (height contour lines and height
> sites)
> -WHITE is the output site file site_rzezba
> -GREEN arrows indicate sections of the input vector not translated to
> sites - near the nodes
> Unclosed line's endings are not translated either.
> This error does not depend on dmax.
> DEVELOPERS! Should I give a bug report?
> Maciek
> P.S.
> I wonder if v.surf.rst uses a smililar way to translate the input vector
> lines to points thus commit the same error?
Similar maybe, but not the same. Are you sure, that those lines have a category?
Radim
