[GRASSLIST:6314] Re: filling nulls in integer raster
Dylan Beaudette dylan at iici.no-ip.org
Sat Apr 2 16:58:00 EST 2005
Maciek,
interesting idea,
I tried using r.neighborhood as well, and it seemed to work ok.
however, i have since discovered that for this particular raster (as
classified slope map of very complex terrain) it was simpler to
generalize the slope map via r.param.scale. since we are mapping at a
rather coarse scale, this method actually captures the larger terrain
features, while masking out the smaller ones..!
i was able to vectorize, and then clean with tool=rmarea to get rid of
any remaining small areas
thanks!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
On Apr 1, 2005, at 1:07 PM, Maciek Sieczka wrote:
> what do you think of the neighborhood modifier:
> 1 change the null value to eg. 0
> 2 r.mapcalc
> 'map_filled=if(map==0,mode(map[-1,-1],map[-1,0],map[
> -1,1],map[0,1],map[1,1],map[1,0],map[1,-1],map[0,-1]),map)'
> 3 repeat until no zeros (may be recognized with "r.info -r
> map_filled") if needed
> or maybe mask the non-null areas, r.grow the mask a few pixels,
> r.neighbors, g.remove MASK, r.patch?
> Maciek
> ----- Original Message ----- From: "Dylan Beaudette"
> <dylan at iici.no-ip.org>
> To: <GRASSLIST at baylor.edu>
> Sent: Friday, April 01, 2005 9:55 PM
> Subject: [GRASSLIST:6310] filling nulls in integer raster
>> Greetings,
>> i have a raster image that i am hoping to vectorize after a bit of
>> generalization with r.reclass.area... however, r.reclass.area leaves
>> nulls
>> in
>> the middle of larger areas of equal value:
>> http://169.237.35.250/~dylan/temp/holes.png
>> i have tried to fill these holes, with r.fillnulls (via RST
>> interpolation)
>> with:
>> r.fillnulls in=asp.large out=asp.final smooth=.01 tension=100
>> and the result looks something like this:
>> http://169.237.35.250/~dylan/temp/fewer_holes.png
>> ...however, is there anyway to get rid of all the nulls, replacing
>> them
>> with
>> the value that is surrounding them?
>> thanks in advance
>> Dylan Beaudette
>> 530.754.7341
