[GRASSLIST:6419] Re: gdall ~ grass
Tue Apr 12 00:00:06 EDT 2005
> in debian I installed
> libgdal1_1.2.5-1_i386.deb
> libgrass_6.0.0-1_i386.deb
> but ldd /usr/lib/libgdal.so.1.6.0 does not anything
> about grass
> what is the problem ?
oh, if you are using Debian it is easy, you just need to install the
GRASS plugin for GDAL: the libgdal1-grass package.
libgdal1-grass - GRASS extension for the Geospatial Data Abstraction
Library
This provides /usr/lib/gdal_GRASS.so
GRASS works fine with this installed.
If you install the qgis-plugin-grass package, that should get you most
of the things you need I think.
Debian's mapserver package is brand new, it should make it into
the Testing archive very soon (maybe today/tomorrow?). see:
http://packages.debian.org/cgi-bin/search_packages.pl?exact=0&searchon=names&version=all&case=insensitive&release=all&keywords=mapserver&arch=any
See the DebianGIS pages, they are doing great things:
  http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
Hamish
