[GRASSLIST:6452] Re: gdal with grass
orkun temiz at deprem.gov.tr
Thu Apr 14 02:38:37 EDT 2005
hello
thank you
it seems ok. gdal_GRASS.so was created
shall I use gdal_GRASS.so instead of libgdal.so.1.6.0 in compiling
"mapserver" as:
../configure ... --with-gdal=/usr/local/lib/gdalplugins
kind regards
Ahmet
On Çrş, 2005-04-13 at 15:58 +0200, Markus Neteler wrote:
> On Wed, Apr 13, 2005 at 04:31:24PM +0300, orkun wrote:
> > when I try gdal without grass
> > make gives
> > .../.libs/libgdal.so: undefined reference to `G_get_color'
> You have to run within the GDAL source code first a
>  make distclean
> Above error indicates that the GDAL tree is not clean from
> leftover GRASS references as you want to compile gdal without grass
> support.
> Markus
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
