[GRASSLIST:6461] Re: d.profile: phenology curve plotting
Markus Neteler neteler at itc.it
Thu Apr 14 06:19:00 EDT 2005
On Wed, Apr 13, 2005 at 01:58:30PM -0400, Martin Wegmann wrote:
> Hello,
> is there a function which plots the phenology of a time series?
> d.profile is doing it spatially but I would like to look at the temporal curve
> of various raster which are a time series.
> e.g. d.profile input=raster.jan, raster.feb, .... raster.dec and then select a
> pixel/area in the image and receive a time profile for each pixel which I
> selected.
hi Martin,
you may use
i.spectral help
Description:
 displays spectral response at user specified locations in images
Modifying this script a bit it you could use g.mlist to insert
your time series and visualize. Needs gnuplot.
Example:
 http://mpa.itc.it/markus/grass60/i_spectral_lsat7_spearfish.jpg
 (LANDSAT7 for Spearfish)
Markus
