[GRASSLIST:6466] plot points in different color
Rado Bonk rado.bonk at jrc.it
Thu Apr 14 09:51:26 EDT 2005
Dear GRASS users,
I have a point data associated with PostgreSQL table. I would like to
fill the points with RGB color based on their attribute (typical desktop
GIS task).
I used "grassrgb" column in PG table and "d.vect -a" command but it did
not fill them with color. Manual page for "d.vect" says that "-a" option
works only for area type vector data;-(((
How can I fill the points with the color based on their attribute in
GRASS?
Thanks,
Rado
PG TABLE:
   east    |   north   |   id   | perc | grassrgb
 481412.45 | 114890.02 | 115758 |   23 | 255:201:0
 436976.24 |  16658.02 | 116194 |   32 | 255:201:0
 513015.88 | 108963.68 | 116285 |   31 | 255:201:0
 563716.89 |  82973.91 | 116442 |   23 | 255:201:0
 559728.19 |  55266.49 | 108167 |   15 | 255:255:0
 523753.84 |  96061.85 | 193121 |    5 | 255:255:0
 554137.91 |  25981.95 | 193180 |    5 | 255:255:0
 525675.06 | -22426.98 | 110254 |   59 | 255:137:0
 582684.19 |  60473.42 | 116426 |   54 | 255:137:0
 502887.37 |  57836.26 | 109116 |   67 | 255:70:0
 577125.90 |  32710.38 | 110049 |   65 | 255:70:0
 420653.26 |  82045.02 | 106823 |   92 | 233:0:54
 413557.10 |  27108.21 | 106898 |   92 | 233:0:54
 431697.39 |  34068.04 | 106955 |   92 | 233:0:54
GRASS COMMAND (layer "netemp" is linked with table above):
 d.vect -a map=netemp icon=basic/circle attrcol=perc
