[GRASSLIST:6495] Re: m.proj s.in.ascii s.to.rast
Fri Apr 15 16:44:47 EDT 2005
Martin du Saire wrote:
> What happened to m.proj(2), s.in.ascii, and s.to.rast?
> I gather these commands no longer exist. In that case I need some help
> figuring out how to do this in 6.0.
m.proj2 just duplicates the functionality of the proj/cs2cs programs
from the PROJ distribution. Use proj or cs2cs instead (cs2cs does
combined projection and datum conversions, proj just does
projections).
GRASS 6.x doesn't have a separate "sites" map type; site maps are now
just vector maps. Look at v.in.ascii and v.to.rast.
