[GRASSLIST:6525] Re: gdall ~ grass
orkun
temiz at deprem.gov.tr
Mon Apr 18 10:03:32 EDT 2005
I put my sources.list file:
deb http://pkg-grass.alioth.debian.org/debian-gis distribution main
non-free contrib
deb-src http://pkg-grass.alioth.debian.org/debian-gis distribution main non-free contrib
apt-get install libgdal1-grass gives:
Reading Package Lists... Done
Building Dependency Tree... Done
W: Couldn't stat source package list http://ftp.tr.debian.org
testing/main Packages
(/var/lib/apt/lists/ftp.tr.debian.org_debian_dists_testing_main_binary-i386_Packages) - stat (2 No such file or directory)W: Couldn't stat source package list http://ftp.tr.debian.org testing/contrib Packages (/var/lib/apt/lists/ftp.tr.debian.org_debian_dists_testing_contrib_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://pkg-grass.alioth.debian.org
distribution/main Packages
(/var/lib/apt/lists/pkg-grass.alioth.debian.org_debian-gis_dists_distribution_main_binary-i386_Packages) - stat (2 No such file or directory)
distribution/non-free Packages
(/var/lib/apt/lists/pkg-grass.alioth.debian.org_debian-gis_dists_distribution_non-free_binary-i386_Packages) - stat (2 No such file or directory)
distribution/contrib Packages
(/var/lib/apt/lists/pkg-grass.alioth.debian.org_debian-gis_dists_distribution_contrib_binary-i386_Packages) - stat (2 No such file or directory)
W: You may want to run apt-get update to correct these problems
E: Couldn't find package libgdal1-grass
regards
On Prş, 2005-04-14 at 11:45 +1200, Hamish wrote:
> > I installed everything about grass in debian
> > apt-cache search "grass" gives:
> > gpx2shp - convert GPS or GPX file to ESRI Shape file
> > grass - Geographic Resources Analysis Support System
> > grass-doc - Geographic Resources Analysis Support System documentation
> > libgrass - GRASS GIS development libraries
> > libgrass-dev - GRASS GIS library development files
> > apt-cache search "libgdal1*"
> > libgdal1 - Geospatial Data Abstraction Library
> > libgdal-doc - Documentation for the Geospatial Data Abstraction Library
> > libgdal1-dev - Geospatial Data Abstraction Library - Development files
> You need to add the DebianGIS repository (use the unstable branch).
> Stuff is slowly filtering into the main Debian repository from there, but
> works pretty well. Some of the java-dependent software (jump) is in
> contrib until it can be made with the free java clones.
> > > See the DebianGIS pages, they are doing great things:
> > > http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
> then:
> $ apt-cache search grass
> libgrass0 - GRASS GIS development libraries
> libgrass0-dev - GRASS GIS library development files
> libgdal1-grass - GRASS extension for the Geospatial Data Abstraction Library
> qgis-plugin-grass - Plugin for accessing GRASS vectors from QGIS
> $ apt-cache search gdal
> gdal-bin - Geospatial Data Abstraction Library - Utility programs
> python-gdal - Python bindings to the Geospatial Data Abstraction Library
> DebianGIS package lists:
> [i386]
> main:
> libjama-java
> libpostgis1-pg74
> libpostgis-doc
> libpostgisjava
> grass
> libgrass0
> libgrass0-dev
> grass-doc
> libjts-java-doc
> libjts-java
> libgdal1-grass
> qgis-plugin-grass
> qgis
> qgis-dev
> mapserver-doc
> perl-mapscript
> mapserver-bin
> cgi-mapserver
> libmapserver-dev
> python-mapscript
> php4-mapscript
> contrib:
> jump-postgis-plugin
> bsh2-doc
> bsh2
> jump
> http://pkg-grass.alioth.debian.org/debian-gis/dists/unstable/main/binary-i386/Packages
> http://pkg-grass.alioth.debian.org/debian-gis/dists/unstable/contrib/binary-i386/Packages
> [source]
> main:
> jama
> postgis
> grass
> jts
> libgdal-grass
> qgis
> mapserver
> contrib:
> postgisdriver-jump
> bsh2
> jump
> http://pkg-grass.alioth.debian.org/debian-gis/dists/unstable/main/source/Sources
> http://pkg-grass.alioth.debian.org/debian-gis/dists/unstable/contrib/source/Sources
> it all works!
> Hamish
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
