[GRASSLIST:6679] Re: libgrass as TGZ package
Roger Bivand Roger.Bivand at nhh.no
Fri Apr 29 08:45:21 EDT 2005
On Fri, 29 Apr 2005, Markus Neteler wrote:
> On Wed, Apr 27, 2005 at 04:58:43PM +0200, Rado Bonk wrote:
> > Dear GRASS users,
> > Please can you point me to the source code of libgrass? I would like to
> > use it within UMN Mapserver environment and can not find it so far.
> Hi Rado,
> libgrass is available here (GRASS CVS):
>  http://freegis.org/cgi-bin/viewcvs.cgi/libgrass/
>  there is a "download tarball" link at bottom.
> But the recommended method is to use the GDAL/GRASS
> plugin. Compilation order:
> - GDAL without GRASS support (you may have to actively disable
>   it using the appropriate configure switches)
> - GRASS 6
> - GDAL/GRASS plugin
> Configure scripts can be grabbed here:
>  http://mpa.itc.it/markus/useful/index.html
>  ->  conf_gdal.sh
>  ->  conf_grass61_linux.sh
>  ->  conf_install_gdal_grass_plugin.sh
Well, after having done this, and:
$ ls -l /usr/local/lib/gdalplugins
total 36
-rwxr-xr-x    1 root     root        34606 Apr 29 14:32 gdal_GRASS.so
(the script presupposes that the user running it has access to
gdalplugins)
I still can't see any access:
$ gdalinfo ~/topics/grassdata/spearfish60/PERMANENT/cellhd/geology
ERROR 4: `/home/rsb/topics/grassdata/spearfish60/PERMANENT/cellhd/geology'
not recognised as a supported file format.
GDALOpen failed - 4
`/home/rsb/topics/grassdata/spearfish60/PERMANENT/cellhd/geology' not
Does GDAL look in gdalplugins by itself? Does it need ldconfig too?
Roger
> Markus
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
