[GRASSLIST:7818] Re: r.cost execution time
Mon Aug 8 12:23:29 EDT 2005
Ellen De Beuckeleer wrote:
> the problem is not solved. My r.cost is still running :(.
> Any suggestions?
r.cost performs extremely badly on large maps where only a fraction is
held in memory. Reducing the region resolution or increasing the
percent_memory= option will get around this.
If the region is actually 640x480, you should have no trouble with
percent_memory=100.
