[GRASSLIST:7821] Re: r.cost execution time
Ellen De Beuckeleer ellen.debeuckeleer at incgeo.be
Mon Aug 8 11:09:32 EDT 2005
PROBLEM SOLVED! my stupid newbe mistake :(
My cost layer contained some negative values. That's why the r.cost got
into an infinite loop.  I hope that by writing this here another newbe
might not loose so much time...
Ellen De Beuckeleer wrote:
> thanx for replying. I tryed to run the r.cost on a smaller map and
> with percent_memory=100. Moreover, I did run it with the -v option. It
> still has the problem of getting stuck in the "finding cost path" part
> (the percentage still raises above 100%). If I do the exact same thing
> in via the GUI, the green status bar first fills up slowely and once
> filled completely it starts again and again and again... but then it
> fills a lot faster. I never get an output map. Can this be because
> there is something wrong with my command line?
> my region is now:
> projection: 0 (x,y)
> zone:       0
> north:      -5864
> south:      -6085
> west:       -9543
> east:       -9365
> nsres:      1
> ewres:      1
> rows:       221
> cols:       178
> I used start coordinates: -9533, -6023 for my last run
> Ellen
>>> the problem is not solved. My r.cost is still running :(.
>>> Any suggestions?
>> r.cost performs extremely badly on large maps where only a fraction is
>> held in memory. Reducing the region resolution or increasing the
>> percent_memory= option will get around this.
>> If the region is actually 640x480, you should have no trouble with
>> percent_memory=100.
