[GRASSLIST:7836] AW: average height
Maik Trömel maik.troemel at maitro.net
Tue Aug 9 10:13:34 EDT 2005
The function exists in Grass 6.0 but it doesn`t work the way i need it.
I tried: r.statistics base=GTOPO30 cover=special-postal-district
method=average output=newmap
But the result are all heights in the postal-district and not the
average height.
I found another method:
r.average base=special-postal-district cover=GTOPO30 output=newmap
With this method i get the average.
But I haven`t found anything similar for minimum and maximum.
Greetings
Maik
-----Ursprüngliche Nachricht-----
Von: turek2 [mailto:turek2 at poczta.fm]
Gesendet: Dienstag, 9. August 2005 11:50
An: Maik Trömel
Betreff: Re: [GRASSLIST:7835] average height
Maik Trömel wrote:
Hello,
i’m searching a function to get the maximum, the minimum und the average
of the heights of a postal-district.
I`ve got the “GTOPO30-Model” and a shapefile with the geometrie of the
postal-districts.
I convertet the shapefile to rasterdata (the postal-codes are still
available). Now i want to use r.mapcalc to get the inforamtions from the
GTOPO30-Model.
I tried:
r.mapcalc newmap=”if(postalmap=5570,max(GTOPO30),null())”
But naturally it didn`t work.
The other functions i tried out didn`t work, too.
Does anybody have an idea how I could get the informations?
Thanks for your help.
Greeting
Maik
try r. statistics, but i'm not sure if it works in grass6.
good luck,
maciek
Startuj z INTERIA.PL! >>> http://link.interia.pl/f186c
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050809/2668600f/attachment.html
