[GRASSLIST:7875] Water height vs. lake area using R.fill.dir
    Armando Scalise
    armandoh at gmail.com
    Thu Aug 11 16:51:09 EDT 2005
I need to estimate the areas of a set of lakes for differente  water
height scenarios.
I am using the SRTM 30 DEM and I was hoping to apply r.fill.dir, to get
the flow direction and water height for given heihg increments.
The documentation for r.fill.in stgates that "The procedure takes an
elevation layer as input and initially fills all the depressions with
one pass across the layer".
Unfortunately, there is no specification as to how tis is done.  I have
searched for the paper describign the algortihm on whihc r.fill.in is
based "Software Tools to Extract Structure from Digital Elevation Data
for Geographic Information System Analysis" by S.K. Jenson and J.O.
Domingue (1988). but I have been unable to find it in the internet.
I need to ask two questions:
 1) is there any other method you would reccomend in addition to
r.fill.dir to compute  water height/areas ratio for depresions using a DEM?
 2) Anybody has a copy of the above cited paper or a detailed
description of the algortuhm?
Cheers thanks
Armando Scalise
