[GRASSLIST:7929] Problem using r.in.gdal to import geoTIFF of US NDVI
Kenneth Waight ken at meso.com
Tue Aug 16 15:39:45 EDT 2005
I'm using r.in.gdal to import a geoTIFF file of U.S. NDVI data.  The
import is performed, but this message is displayed and the data
doesn't seem to be projected correctly:
GRASS_INFO_WARNING(20541,1): Datum
'Not_specified_based_on_Authalic_Sphere' not recognised by GRASS and
no parameters found. Datum transformation will not be possible using
this projection information.
Over-riding projection check.
Proceeding with import...
CREATING SUPPORT FILES FOR ndvi.2004113.test
SETTING GREY COLOR TABLE FOR ndvi.2004113.test (8bit, full range)
It's close but is a few km off when I reproject to a lat-lon grid.
Here's the dataset information:
http://glcf.umiacs.umd.edu/data/modis/ndvi/guide.shtml
U.S.16 day Vegetation Index User Guide
* Projection: Alber's Equal Area Conic Conformal
reprojected from native MODIS projection: Sinusoidal
Central Meridian used was 96d W
std Parallels of 29d 30' 0" and 45d 30' 0"
Latitude of Origin is 0d 0' 0"
Easting & Northing are 0.0000000000 m
Datum: sphere (a sphere of radius 6370997 m)
Resolution is 250 meters
***NOTE*** - When you load the geotiff, many programs may not
correctly recognize the datum and report a wrong datum (i.e., WGS
1984). THE DATUM IS THE SPHERE USED IN MODIS DATA, WITH A RADIUS OF
6370997 METERS!!!
Any ideas?
Ken
