[GRASSLIST:8053] problems compiling GRASS-6.0.1 Fedora 4
Jaime Carrera jaicarrerahdez at yahoo.com
Wed Aug 24 19:19:11 EDT 2005
I'm trying to compile GRASS 6.0.1 on fedora 4 but I
ran into problems. Yesterday I compiled this version
and the CVS version without a single error but today,
after removing my grass 6.0.0 directory I just can't
compile 6.0.1 nor the CVS version.
[jaime at localhost grass-6.0.1]$ ./configure
--with-postgres-includes=/usr/local/pgsql/include
--with-postgres-libs=/usr/local/pgsql/lib
--with-fftw=yes --with-motif=yes -with-cxx -with-gdal
GRASS is now configured for:  i686-pc-linux-gnu
 Source directory:            /home/jaime/grass-6.0.1
 Build directory:             /home/jaime/grass-6.0.1
 Installation directory:      /usr/local/grass-6.0.1
 Startup script in directory: ${exec_prefix}/bin
 C compiler:                  gcc -g -O2
 C++ compiler:                c++ -g -O2
 FORTRAN compiler:
 Building shared libraries:   yes
  NVIZ:                       yes
  X11 support:                yes
  JPEG support:               yes
  TIFF support:               yes
  PNG support:                yes
  Tcl/Tk support:             yes
  PostgreSQL support:         yes
  MySQL support:              no
  OpenGL(R) support:          yes
  ODBC support:               no
  FFTW support:               yes
  BLAS support:               no
  LAPACK support:             no
  Motif support:              yes
  FreeType support:           no
  GLw support:                no
  NLS support:                no
  Readline support:           no
  C++ support:                yes
  openDWG support:            no
  GDAL support:               yes
  OGR support:                yes
After running make I get the following errors:
GRASS GIS compilation log
Started compilation: Wed Aug 24 18:45:20 EDT 2005
Errors in:
/home/jaime/grass-6.0.1/lib/proj
/home/jaime/grass-6.0.1/lib/vector/diglib
/home/jaime/grass-6.0.1/lib/vector/Vlib
/home/jaime/grass-6.0.1/lib/sites
/home/jaime/grass-6.0.1/lib/rst/interp_float
/home/jaime/grass-6.0.1/lib/ogsf
/home/jaime/grass-6.0.1/db/drivers/ogr
/home/jaime/grass-6.0.1/display/d.extend
/home/jaime/grass-6.0.1/display/d.path
/home/jaime/grass-6.0.1/display/d.vect
/home/jaime/grass-6.0.1/display/d.vect.chart
/home/jaime/grass-6.0.1/display/d.what.vect
/home/jaime/grass-6.0.1/display/d.where
/home/jaime/grass-6.0.1/display/d.zoom
/home/jaime/grass-6.0.1/general/g.proj
/home/jaime/grass-6.0.1/general/g.region/cmd
/home/jaime/grass-6.0.1/general/manage/lib
/home/jaime/grass-6.0.1/general/manage/cmd
/home/jaime/grass-6.0.1/imagery/i.vpoints
/home/jaime/grass-6.0.1/ps/ps.map
/home/jaime/grass-6.0.1/raster/r.contour
/home/jaime/grass-6.0.1/raster/r.cost
/home/jaime/grass-6.0.1/raster/r.flow
/home/jaime/grass-6.0.1/raster/r.le/r.le.setup
/home/jaime/grass-6.0.1/raster/r.proj
/home/jaime/grass-6.0.1/raster/r.random
/home/jaime/grass-6.0.1/raster/r.region
/home/jaime/grass-6.0.1/raster/r.resamp.rst
/home/jaime/grass-6.0.1/raster/r.sun
/home/jaime/grass-6.0.1/raster/r.sunmask
/home/jaime/grass-6.0.1/raster/r.to.vect
/home/jaime/grass-6.0.1/raster/r.in.gdal
/home/jaime/grass-6.0.1/vector/v.buffer
/home/jaime/grass-6.0.1/vector/v.build
/home/jaime/grass-6.0.1/vector/v.build.polylines
/home/jaime/grass-6.0.1/vector/v.category
/home/jaime/grass-6.0.1/vector/v.clean
/home/jaime/grass-6.0.1/vector/v.convert
/home/jaime/grass-6.0.1/vector/v.db.connect
/home/jaime/grass-6.0.1/vector/v.db.select
/home/jaime/grass-6.0.1/vector/v.digit
/home/jaime/grass-6.0.1/vector/v.distance
/home/jaime/grass-6.0.1/vector/v.extract
/home/jaime/grass-6.0.1/vector/v.hull
/home/jaime/grass-6.0.1/vector/v.info
/home/jaime/grass-6.0.1/vector/v.in.ascii
/home/jaime/grass-6.0.1/vector/v.in.db
/home/jaime/grass-6.0.1/vector/v.in.region
/home/jaime/grass-6.0.1/vector/v.in.sites
/home/jaime/grass-6.0.1/vector/v.kcv
/home/jaime/grass-6.0.1/vector/v.kernel
/home/jaime/grass-6.0.1/vector/v.label
/home/jaime/grass-6.0.1/vector/v.proj
/home/jaime/grass-6.0.1/vector/v.mkgrid
/home/jaime/grass-6.0.1/vector/v.neighbors
/home/jaime/grass-6.0.1/vector/v.net
/home/jaime/grass-6.0.1/vector/v.net.alloc
/home/jaime/grass-6.0.1/vector/v.net.iso
/home/jaime/grass-6.0.1/vector/v.net.path
/home/jaime/grass-6.0.1/vector/v.net.salesman
/home/jaime/grass-6.0.1/vector/v.net.steiner
/home/jaime/grass-6.0.1/vector/v.normal
/home/jaime/grass-6.0.1/vector/v.out.ascii
/home/jaime/grass-6.0.1/vector/v.out.dxf
/home/jaime/grass-6.0.1/vector/v.out.pov
/home/jaime/grass-6.0.1/vector/v.overlay
/home/jaime/grass-6.0.1/vector/v.patch
/home/jaime/grass-6.0.1/vector/v.perturb
/home/jaime/grass-6.0.1/vector/v.qcount
/home/jaime/grass-6.0.1/vector/v.random
/home/jaime/grass-6.0.1/vector/v.reclass
/home/jaime/grass-6.0.1/vector/v.sample
/home/jaime/grass-6.0.1/vector/v.segment
/home/jaime/grass-6.0.1/vector/v.select
/home/jaime/grass-6.0.1/vector/v.surf.idw
/home/jaime/grass-6.0.1/vector/v.surf.rst
/home/jaime/grass-6.0.1/vector/v.transform
/home/jaime/grass-6.0.1/vector/v.to.db
/home/jaime/grass-6.0.1/vector/v.to.points
/home/jaime/grass-6.0.1/vector/v.to.rast
/home/jaime/grass-6.0.1/vector/v.type
/home/jaime/grass-6.0.1/vector/v.univar
/home/jaime/grass-6.0.1/vector/v.voronoi
/home/jaime/grass-6.0.1/vector/v.what.rast
/home/jaime/grass-6.0.1/vector/v.vol.rst
/home/jaime/grass-6.0.1/vector/v.out.ogr
/home/jaime/grass-6.0.1/vector/v.in.ogr
/home/jaime/grass-6.0.1/vector/v.external
/home/jaime/grass-6.0.1/visualization/nviz
Finished compilation: Wed Aug 24 18:49:28 EDT 2005
(In case of errors please change into the directory
with error and run 'make')
Any help will be appreciated, thanks!
Jaime
__________________________________________________
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
