[GRASSLIST:8076] Re: compilation problem
Martin Landa landa at gama.fsv.cvut.cz
Fri Aug 26 06:24:55 EDT 2005
I found out that I get these errors only when I use gcc-4.0 (not
3.4). So the problem is partly solved;-)
Martin
On Thu, 25 Aug 2005, Martin Landa wrote:
> Hi all,
> I cannot compile grass6 any more...
> CFLAGS="-g -Wall -ansi -D_BSD_SOURCE=1 -D_SVID_SOURCE=1
> -D_POSIX_SOURCE=1 -D_POSIX_C_SOURCE=199506L" \
> ./configure --prefix=/usr/local \
> --with-tcltk-includes=/usr/include/tcl8.3
> --with-tcltk-libs=/usr/lib/tcl8.3 \
> --with-postgresql --with-postgres-includes=/usr/include/postgresql
> --with-postgres-libs=/usr/lib/postgresql \
> --with-gdal=/usr/local/bin/gdal-config  \
> --with-proj --with-proj-includes=/usr/local/include
> --with-proj-libs=/usr/local/lib \
> --with-blas --with-motif --with-glw --with-nls --with-readline \
> --with-lapack --with-lapack-libs=/usr/lib/atlas \
> --with-cxx --enable-large-file \
> --with-freetype --with-freetype-includes=/usr/include/freetype2
> I get these errors:
> Errors in:
> /usr/src/gis/grass/grass6/lib/gmath
> /usr/src/gis/grass/grass6/lib/imagery
> /usr/src/gis/grass/grass6/lib/rst/interp_float
> /usr/src/gis/grass/grass6/imagery/i.class
> /usr/src/gis/grass/grass6/imagery/i.cluster
> /usr/src/gis/grass/grass6/imagery/i.gensig
> /usr/src/gis/grass/grass6/imagery/i.gensigset
> /usr/src/gis/grass/grass6/imagery/i.group
> /usr/src/gis/grass/grass6/imagery/i.his.rgb
> /usr/src/gis/grass/grass6/imagery/i.maxlik
> /usr/src/gis/grass/grass6/imagery/i.ortho.photo/libes
> /usr/src/gis/grass/grass6/imagery/i.ortho.photo/menu
> /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.2image
> /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.2target
> /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.camera
> /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.elev
> /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.init
> /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.rectify
> /usr/src/gis/grass/grass6/imagery/i.ortho.photo/photo.target
> /usr/src/gis/grass/grass6/imagery/i.points
> /usr/src/gis/grass/grass6/imagery/i.rectify
> /usr/src/gis/grass/grass6/imagery/i.rgb.his
> I am using Debian GNU/Linux - unstable ...
> e.g.
> $ cd /usr/src/gis/grass/grass6/lib/gmath
> $ make
> gcc -I/usr/src/gis/grass/grass6/include
> -I/usr/src/gis/grass/grass6/dist.i686-pc-linux-gnu/include/grass  -g
> -Wall -ansi -D_BSD_SOURCE=1 -D_SVID_SOURCE=1 -D_POSIX_SOURCE=1
> -D_POSIX_C_SOURCE=199506L  -Wall -Wconversion -Wno-implicit-int
> -fPIC    -DPACKAGE=\""grasslibs"\"      -DPACKAGE=\""grasslibs"\"
> -I/usr/src/gis/grass/grass6/dist.i686-pc-linux-gnu/include/grass \
> 								 -o
> 								 OBJ.i686-pc-linux-gnu/del2g.o -c del2g.c
> In file included from /usr/src/gis/grass/grass6/include/la.h:28,
>                  from /usr/src/gis/grass/grass6/include/gmath.h:29,
>                  from del2g.c:22:
> /usr/include/g2c.h:21: error: syntax error before 'integer'
> /usr/include/g2c.h:22: error: syntax error before 'uinteger'
> /usr/include/g2c.h:29: error: syntax error before 'logical'
> /usr/include/g2c.h:33: error: syntax error before 'longint'
> /usr/include/g2c.h:34: error: syntax error before 'ulongint'
> /usr/include/g2c.h:55: error: syntax error before 'flag'
> /usr/include/g2c.h:56: error: syntax error before 'ftnlen'
> /usr/include/g2c.h:57: error: syntax error before 'ftnint'
> /usr/include/g2c.h:62: error: syntax error before 'flag'
> /usr/include/g2c.h:64: error: syntax error before 'ciend'
> /usr/include/g2c.h:66: error: syntax error before 'cirec'
> /usr/include/g2c.h:71: error: syntax error before 'flag'
> /usr/include/g2c.h:73: error: syntax error before 'iciend'
> /usr/include/g2c.h:75: error: syntax error before 'icirlen'
> /usr/include/g2c.h:76: error: syntax error before 'icirnum'
> /usr/include/g2c.h:81: error: syntax error before 'flag'
> /usr/include/g2c.h:84: error: syntax error before 'ofnmlen'
> /usr/include/g2c.h:88: error: syntax error before 'orl'
> /usr/include/g2c.h:90: error: syntax error before '}' token
> /usr/include/g2c.h:94: error: syntax error before 'flag'
> /usr/include/g2c.h:97: error: syntax error before '}' token
> /usr/include/g2c.h:101: error: syntax error before 'flag'
> /usr/include/g2c.h:107: error: syntax error before 'flag'
> /usr/include/g2c.h:110: error: syntax error before 'infilen'
> /usr/include/g2c.h:111: error: syntax error before '*' token
> /usr/include/g2c.h:112: error: syntax error before '*' token
> /usr/include/g2c.h:113: error: syntax error before '*' token
> /usr/include/g2c.h:114: error: syntax error before '*' token
> /usr/include/g2c.h:116: error: syntax error before 'innamlen'
> /usr/include/g2c.h:118: error: syntax error before 'inacclen'
> /usr/include/g2c.h:120: error: syntax error before 'inseqlen'
> /usr/include/g2c.h:122: error: syntax error before 'indirlen'
> /usr/include/g2c.h:124: error: syntax error before 'infmtlen'
> /usr/include/g2c.h:126: error: syntax error before 'informlen'
> /usr/include/g2c.h:128: error: syntax error before 'inunflen'
> /usr/include/g2c.h:129: error: syntax error before '*' token
> /usr/include/g2c.h:130: error: syntax error before '*' token
> /usr/include/g2c.h:132: error: syntax error before 'inblanklen'
> /usr/include/g2c.h:138: error: syntax error before 'integer'
> /usr/include/g2c.h:144: error: syntax error before '}' token
> /usr/include/g2c.h:153: error: syntax error before 'ftnlen'
> /usr/include/g2c.h:155: error: syntax error before '}' token
> /usr/include/g2c.h:193: error: syntax error before '*' token
> /usr/include/g2c.h:193: error: 'integer' declared as function
> returning a function
> /usr/include/g2c.h:193: error: 'integer' redeclared as different kind
> of symbol
> /usr/include/g2c.h:21: error: previous declaration of 'integer' was
> here
> /usr/include/g2c.h:198: error: syntax error before '*' token
> /usr/include/g2c.h:198: error: 'logical' declared as function
> /usr/include/g2c.h:198: error: 'logical' redeclared as different kind
> of symbol
> /usr/include/g2c.h:29: error: previous declaration of 'logical' was
> here
> In file included from /usr/src/gis/grass/grass6/include/la.h:46,
>                  from del2g.c:22:
> /usr/src/gis/grass/grass6/include/blas.h:8: error: syntax error before
> 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:9: error: syntax error before
> 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:10: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:13: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:14: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:15: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:16: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:17: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:18: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:19: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:20: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:21: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:22: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:28: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:29: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:30: error: syntax error
> before 'ftnlen'
> /usr/src/gis/grass/grass6/include/blas.h:31: error: syntax error
> before 'ftnlen'
> Can anyone help me please? Maybe problem with lapack3-dev and
> refblas3-dev deb package??
> Martin
Martin Landa <landa at gama.fsv.cvut.cz> * http://gama.fsv.cvut.cz/~landa *
CTU Prague, Faculty of Civil Engineering, Czech Republic
