[GRASSLIST:8124] Re: point xyz-output for cvs 6.1
Tue Aug 30 01:12:17 EDT 2005
> I fail to get xyz-output from v.out.ascii on GRASS cvs 6.1.
> Just x|y|nodeid is written.
> Can anyone help?
Is the z data actually a 3d coordinate or is it an attribute column?
(check vector file type with v.info)
If it is an attribute column you can use the v.out.ascii.db script
available on the wiki add-ons page:
 http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassAddOns
Hamish
