[GRASSLIST:8146] Re: nviz segfault
Stefan Istvan stefi at geohidroterv.hu
Wed Aug 31 04:28:43 EDT 2005
2005-08-31, sze keltezéssel 10:13-kor Glynn Clements ezt írta:
> Stefan Istvan wrote:
> > I found out that if I start Grass locally, then I can start nviz, but if
> > I use Grass remotely, nviz doesn't start.
> Does your X server support the GLX extension?
Yes.
> Which OpenGL libraries is the nviz binary using? If they were supplied
> by your graphics card vendor (e.g. nVidia or ATI), they may only work
> with a local X server.
No, it uses the library of Xorg:
# ldd /usr/local/grass-6.0.1/bin/nviz
libGL.so.1 => /usr/lib/opengl/xorg-x11/lib/libGL.so.1 (0x40743000)
> Do other OpenGL programs (e.g. glxinfo, glxgears) work?
Yes, a little bit slow, but they run (glxgears).
