[GRASSLIST:9380] view surface ffrom below in NVIZ
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Thu Dec 8 09:49:12 EST 2005
So, after some workaround I managed to get my cave data into GRASS,
and I can visualize it in NVIZ. The thin is, since it is a cavern, I'd
like to view it from below the topographic surface, but when I change
the Height in NVIZ to a value smaller than the minimum of the surface,
the surface is flipped upside down. NVIZ inverts the situation, so I
end up looking a upside down surface from above, not a correct durface
from below. See the attached files. In the first image, the cave is
below the surface, but with a small change in height, I get the second
image, with the cave above the "inverted"surface.
any help will be appreciated.
thanks
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20051208/b44492af/nviz_cave_below.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20051208/b44492af/nviz_cave_above.jpg
