[GRASSLIST:9497] v.to.rast problem
orkun temiz at deprem.gov.tr
Thu Dec 15 05:13:42 EST 2005
>>hello
>>what can I do to overcome the problem ?
>>v.to.rast input=jgenel1 layer=1 output=jgenel1 use=attr column=yas
>>rows=4096
>>Loading vector information ...ERROR: Column type not supported by
>>db_select_to_array()
>please post the result of
>v.info -c jgenel1
>to the list as well.
>regards
>Markus
>>regards
>>Ahmet Temiz
>>______________________________________
>>XamimeLT - installed on mailserver for domain @deprem.gov.tr
>>Queries to: postmaster at deprem.gov.tr
>>The views and opinions expressed in this e-mail message are the sender's
>>own
>>and do not necessarily represent the views and the opinions of Earthquake
>>Research Dept.
>>of General Directorate of Disaster Affairs.
>>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
>>olarak T.C.
>>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
>>nitelikte degildir.
thank you for your quick help
v.info -c jgenel1
Displaying column type for database connection of layer 1:
INTEGER|cat
CHARACTER|yas
INTEGER|count
DOUBLE PRECISION|sum_cat
in postgresql
bzk=# \d jgenel1
          Table "public.jgenel1"
Column  |         Type          | Modifiers
cat     | integer               |
yas     | character varying(80) |
count   | integer               |
sum_cat | double precision      |
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
