[GRASSLIST:9502] Re: problem with v.to.rast
ivan marchesini marchesini at unipg.it
Thu Dec 15 05:04:57 EST 2005
The column must be of integer type...
which type is your "yas" column???
regards
Il giorno gio, 15-12-2005 alle 11:33 +0200, orkun ha scritto:
> hello
> what can I do to overcome the problem ?
>  v.to.rast input=jgenel1 layer=1 output=jgenel1 use=attr column=yas
> rows=4096
> Loading vector information ...ERROR: Column type not supported by
> db_select_to_array()
> regards
> Ahmet Temiz
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the sender's own
> and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
