[GRASSLIST:9535] Re: g.access
Leonardo Lami lami at faunalia.it
Fri Dec 16 06:30:39 EST 2005
Hi all,
only a simple question about g.access or similar.
there is a command that permits the write access on the mapsets by the group
users or only the owner of the mapset can have write access to it?
thanks
Leonardo
Alle 00:16, lunedì 12 dicembre 2005, Hamish ha scritto:
> > to change the permit on the mapsets for the utents of the machine ,
> > may I do does edit g.access.
> Others on the same machine will be allowed read access if the UNIX file
> permissions are ok and they have not been specifically denied access
> with g.access. Only the owner of the mapset can have write access to it,
> even if the UNIX file permissions say that others may write to it.
> see the g.access help page. see also g.mapsets.
> Hamish
