[GRASSLIST:9542] Re: Replacement for r.volume
Fri Dec 16 08:05:07 EST 2005
> What is the replacement command for r.volume, which doesn't seem to
> exist in GRASS 6.0 ?
I just added it to the 6.1-cvs. I haven't tested but it will probably
run. :)  (at least it builds ok)
The centroid ouput code needs updating to the new vector points format &
it needs some DB code added for creating the linked attribute table.
Centroid output is optional, so worse case we just disable that code if
we decide to do a 6.2 stable release and it isn't fixed yet.
hopefully someone who knows how to use it can take it from here.
Hamish
