[GRASSLIST:9549] Re: rectifying images
Wolfgang Zillig wolfgang.zillig at web.de
Fri Dec 16 15:17:55 EST 2005
Hello Markus,
yes I'm interested! I hope i can compile it as I'm still a quite
unexperienced grass and cygwin user. But I will try my best.
regards
Wolfgang
Markus Neteler schrieb:
>hi,
>a student of us has implemented improved versions of
>i.points and i.rectify based on previous work as published
>in our last year's Bangkok paper.
>The new version
>- use FFT correlation to automatically search for ground
>  control points in a user given window pair (so, just zoom
>  more or less the same zone in the master and the slave
>  image)
>- do this for the entire stripe of images
>- bad GCPs are identified and eliminated
>- run the modified i.rectify to rectify the entire stripe.
>We are using this to geocode historical images. I still
>have to cleanup the code to the current coding standards,
>then I need a beta tester :-)
>If course you can also work with just 2 overlapping images
>and enjoy the automated GCP search.
>Interested?
>Markus
>On Fri, Dec 16, 2005 at 03:13:03PM +0100, Wolfgang Zillig wrote:
>>I'm not sure if this helps for my problem (perhaps I was not clear
>>enough in my description). The problem is, that I have one original
>>images which I want to use as reference and all others are more or less
>>deformed but no one at the same level. So I think I will have mark my
>>reference points in all deformed images. When I understand right
>>grouping is good, when you have many images whith the same deformation,
>>or am I wrong?
>>Wolfgang
>>Hamish schrieb:
>>>>I need to rectify several images in the next time. Is there a way to
>>>>automatize this procedure a little bit? I have the "original" image and
>>>>then about 10 to 20 images which needs to be corrected that they refer
>>>>to the original one. I thought of something like saving the correction
>>>>points of the original image to an file, so that I don't need to mark
>>>>again (the reference points will be the same for all images) and I only
>>>>need to specify them in the images which needs to be rectified.
>>>Add all the images to a group, then rectify the lot.
>>>i.group input=name[,name,...]
>>>i.rectify -a
>>>Hamish
