[GRASSLIST:9619] Re: Using unixODBC to connect GRASS to MySQL [Mac] - please test iODBC anyone
Nick Cahill ndcahill at facstaff.wisc.edu
Fri Dec 23 00:40:29 EST 2005
Yes, I found that documentation too, and followed it - plain ASCII,
Host, Port, ServerDataSource, path to the internals of the bundled
driver. They say that the OpenLink ODBC Administrator can test
whether the connection is set up correctly, but the built-in Mac OSX
version doesn't seem to have that capability; and I can't find the
OpenLink version on the web. So I can't check whether things are
working properly from the Filemaker/FM ODBC end. The error messages
in db.test and db.describe seem to suggest that GRASS is seeing the
SequeLink driver but getting no further with that - which might
suggest that my ODBC setup isn't working right. Is there another way
to test it?
I remember reading Lorenzo's message about problems with GRASS ODBC
some months ago when this came up - Kurt Springs was particularly
interested in this possibility. I think it would be a big plus to
GRASS if it could access Filemaker databases. I suspect I'm not alone
in having a lot of useful data in Filemaker, and not wanting to
maintain that in two different databases.
Cheers,
Nick
On Dec 23, 2005, at 1:39 AM, William Kyngesburye wrote:
> I found the FileMaker documentation PDFs at the FileMaker site, so
> now I have a beter understanding of this.  When you setup the DSN,
> did you specify the Host, Port and ServerDataSource as Keywords?
> That error below implies that at least the Host (should be
> localhost) is missing in the DSN.
> Also, they mention that only plain ASCII is supported in DB
> filenames (no accents or unicode).  What it doesn't say is that
> probably also applies to the whole path to the database.
> If you're already in holiday mode, Merry Xmas and I'll probably
> hear from you next week.
> On Dec 22, 2005, at 3:46 PM, Nick Cahill wrote:
>> I hadn't set up Filemaker with any user or password protection; I
>> added that, ran it through db.login, and it still didn't work.
>> I added the port to the Firewall, and then just turned the
>> firewall off; still no luck.
>> Tried db.describe:
>> db.describe table=ODBCTestTable driver=odbc database=ODBCTest
>> DBMI-ODBC driver error: SQLConnect():
>> [DataDirect][ODBC SequeLink driver][SequeLink Client]TCP/IP host
>> is not specified. (5154)
>> I'll have to go read up on ODBC, but not til after Christmas.
>> Merry Christmas to all --
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike.  Cheating, murdering, lying,
> fighting, and all for things that the beasts of the jungle would
> not deign to possess - money to purchase the effeminate pleasures
> of weaklings.  And yet withal bound down by silly customs that make
> them slaves to their unhappy lot while firm in the belief that they
> be the lords of creation enjoying the only real pleasures of
> existence....
> - the wisdom of Tarzan
