[GRASSLIST:5713] Re: Creating DTM from shapefiles
Māris Nartišs maris.nartiss at gmail.com
Thu Feb 10 08:58:18 EST 2005
thanks. I renamed vect1 cat column to cat1. Then reconnectd db usin
cat1 as category. Then I used v.append and got good results: one
vector data set with single db. This db now contains columns cat, cat1
and augst. cat = cat1 for points from vect1 data;  cat1 = 0 and with
new cat vaules for data from vect2. Most important - data in augst is
for all records. Now I can delete unnecesary cat1 and will got 2
merged vector data sets :)
Actualy I cant fuly understand how I got results, but I have them :)
Some more easy way for all grass users would be nice (developers - you
read this?).
TNX all,
Maris
On Thu, 10 Feb 2005 13:18:03 +0100 (CET), Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> It seems to try to create a table containing all columns from the original two
> tables. Try renaming the columns of one of the tables to CAT2 and AUGST2 and
> see what happens.
> If the above suggestion works, you could then use simple SQL to populate one
> CAT column with unique cat nums.
> Moritz
