[GRASSLIST:5782] Re: 2GB+ in Grass 6.0
Māris Nartišs maris.nartiss at gmail.com
Tue Feb 15 09:27:29 EST 2005
How can this be enabled in ./configure? Or it is autodetected? How can
I check is my Grass compiled with this -Dblahblah option?
wbr,
Maris.
On Tue, 15 Feb 2005 10:40:07 -0300, Christian Ferreira
<christian.grass at gmail.com> wrote:
>  GRASS 6.0 supports reading and writing large files (> 2GB) if it is
> possible in your operating system. If you compile with
> -D_FILE_OFFSET_BITS=64, you should be able to have raster maps which
> are larger than 2Gb.
> Did you tried this?
> Cheers
> Christian
> On Mon, 14 Feb 2005 20:38:24 +0100, Maciek Sieczka <werchowyna at pf.pl> wrote:
> > Folks
> > Is it possible to load a 4.1 GB GeoTiff DEM into Grass 6.0 location? I'm
> > getting "file size limit exceeded". Please help!
> > Maciek
