[GRASSLIST:5865] Re: Problem installing grass-6.0.0beta2
Stephan Holl sholl at gmx.net
Mon Feb 21 12:03:37 EST 2005
Hello David,
On Mon, 21 Feb 2005 07:24:22 -0800 David Adam <david at quercus.org> wrote:
> *The* **libgdal.so.1 *file does exist, at /usr/local/lib/libgdal.so.1,
> so I apparently need
> to modify a search path somewhere, but cannot find anything in the
> docs.  Can anyone
> help me out?  TIA
you need to add the path /usr/local/lib
to /etc/ld.so.conf
and run
ldconfig
afterwards.
This should solve the problem of not finding the lib.
hth
	Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050221/7f159124/attachment.bin
