[GRASSLIST:5893] Re: searching grass mailing list
Wed Feb 23 18:11:33 EST 2005
> I wanted to search the grass M.L. archives because I had problems
> importing  dxf with v.in.ogr (200 Mb of laser scanner 3D points, some
> joker exported  them in dxf instead of ascii and I wanted to use grass
> to import them and  expor in 3d ascii points) using grass60 and I
> heard someone already solved  the problem thanks to the mailing list.
You'll probably want to use v.in.dwg [*] for this. v.in.dxf in GRASS 5.4
might work too.
[*] non-Free libary req., must build yourself & can't redistribute.
I don't think v.in.ogr supports dxf?
  http://gdal.org/ogr/ogr_formats.html
> The problem is that searching the  list with htdig I do not get any
> results for any combination of search  words, even a single word!  Is
> there any problems with the htdig search  engine or am I missing
> something??
... which one? The http://grass.institutoecos.org.br/grass-list/ was
broken last time I tried and the Gmane one only keeps recent messages,
but the main one works fine:
  http://grass.ibiblio.org/searchgrass.php
I've just highlighted the link to the main search page on the Mailing
list webpage, hope that helps.
Hamish
