[GRASSLIST:7016] Re: Starting GRASS 6
Lorenzo Moretti lorenzo.moretti at bologna.enea.it
Sun Jun 5 18:21:38 EDT 2005
Hi David
>Hello,
>I'm running OSX 10.4.  I've just downloaded and
>installed Grass-OSX-6.0.0-1.dmg.  I've installed the Tiger Patch,
>and am attempting to open GRASS.  Double-cliking on the GRASS icon
>opens the Grass 6.0 startup window.  I leave the startup settings in
>the default modes (graphic and OS X).  When I click on "Start" I
>receive the following message in a terminal window:
>xterm: Can't execvp
>/Applications/Grass/grass60.app/Contents/Resources/grass-6.1.cvs/grass61:
>No such file or directory
>I'll appreciate any help or suggestions
>Dave Kindem
>Grand Haven, MI
You have an old patch that worked in an old 6.1.cvs.
Please download the patch for 6.0.0:
http://wwwamb.bologna.enea.it/forgrass/files/grass60-patch-OSX-10.4.zip
 From README file.
GRASS 6.0.0 PATCH FOR MAC OS X 10.4.x (updated)
This patch is only for Grass 6.0.0 and it works in any operating
system: 10.2.x, 10.3.x and 10.4.x.
Unzip the folder and you have 2 files: this "README" file and
"script.scpt" file.
INSTALL
- exit from Grass and X11 application;
- go to your Grass folder, usually /Applications/Grass folder and
open your grass60.app application;
- select grass60 icon, press ctrl key and a clic on mouse and you see
the menu where you select "Show Package Contents";
- go to "grass60.app/Contents/Resources/Scripts" folder;
- inside you see 1 file with the name "script.scpt";
- substitute this file with the new file with the same name
"script.scpt" inside "grass60-patch-OSX-10.4" folder;
- done
Run now grass60 and press START button to start.
4-May-2005
Remember: last 6.1.cvs
(http://wwwamb.bologna.enea.it/forgrass/downloadcvs.htm) it's already
Tiger compatible: no patch is need.
You can use last Grass 6.1.cvs because it has many new features: it
requires the presence of grass60.app in /Applications/Grass folder.
If you use old Grass 5.4.0 you can apply the patch for Tiger:
http://wwwamb.bologna.enea.it/forgrass/files/grass54-patch-OSX-10.4.zip
Bye
________________________________________________________________________
||      Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
||/|/|  ENEA prot/idr          Web: http://wwwamb.bologna.enea.it/
||   |  via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~  40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050606/c8ab2299/attachment.html
