[GRASSLIST:7141] QGIS-GRASS and mac os x
Konstantinos Theofilis theofilis at macland.gr
Mon Jun 13 07:19:11 EDT 2005
Thanks for the feedback.
QGIS seems a very nice solution but I cant get it to work with GRASS.
Any feedback from OS X users would be greatly appreciated
I downloaded QGIS for mac os x and I followerd the instructions int
he ReadMe file for activating GRASS support. But when I start QGIS
(from within Terminal) I get
dyld: Symbol not found: __cg_jpeg_resync_to_restart
   Referenced from: /System/Library/Frameworks/
ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/
Versions/A/ImageIO
   Expected in: /usr/local/grasslib/lib/libJPEG.dylib
Trace/BPT trap
[skulls-ibook-g4:~] skull% /Applications/qgis.app/Contents/MacOS/qgis
Versions/A/ImageIO
I have the binaries of Lorenzo installed
Then jpeg lib that I have in /usr/local/grasslib/lib is libjpeg.dylib
(not capital letters)
Kostas Theofilis
On 13 Jun 2005, at 09:17, Otto Dassau wrote:
> Am Montag, 13. Juni 2005 01:07 schrieb Konstantinos Theofilis:
>> Hi list,
>> I am digitizing a map and I have some issues due to the lack of a
>> "join" operation in v.digit module. Since I have to start a new line
>> everytime I use the "pan" function, I use v.build.polylines to joine
>> them afterwards. Trouble is, that the new vector map generated from
>> v.build.polylines does not preserve the table structure (the "height"
>> column that I add to to the original vector map).
>> Any workaround?
> Hi,
> you could use Quantum GIS to digitize within the GRASS database,
> AFAIK it
> allows what you are looking for.
> BTW: There already exists a wish list for v.digit in the bugtracker
> (03/2005)
> http://intevation.de/rt/webrt?serial_num=3090&display=History
> 1) Visualization of snapping radius.
> 2) Snapping to lines
> 3) Snap to vetices and nodes.
> 4) virtually snapping to a background map.
> maybe you can add your wish as well,
> but it seems that the development prefers QGIS as digitizing tool.
>   Otto
