[GRASSLIST:7171] Re: crop of raster - once again
Ian MacMillan ian_macmillan at umail.ucsb.edu
Wed Jun 15 13:45:03 EDT 2005
Axel, you might try
r.mapcalc MASK='if(V_rast=0, null(), 1)'
I am not sure if this will work, but it is worth a try.
G'luck,
-Ian
On Jun 15, 2005, at 6:57 AM, Axel Orth wrote:
> Hey,
> I had some success with cropping my raster maps with borders of
> municipalities (available as vector - converted to raster) and thought
> I figured out how it works.
> But now I try do do the same with some other data and strange things
> happen:
> import raster map "MAP" - import vector "V" - do raster conversation
> with vector and get the raster map "V_rast"
> set the region: g.region rast=V_rast zoom=V_rast
> create the mask: g.copy V_rast,MASK
> create new map based on the existing map while only the area of the
> mask is taken into consideration: r.mapcalc MAP_crop=MAP
> Problem: the resulting map MAP_crop is just a colored rectangle - the
> size of the rectangle is equal to the bounding box of V_rast
> By chance I made some errors and somehow got the result i wanted:
> instead of the r.mapcalc command shown above I did:
> r.mapcalc
> MAP_crop=MAP end -> syntax error
> MAP looks now exactly the way I wanted. When I leave GRASS, start
> again then MAP looks like I had when imported it.
> I have no clue what's this is all about and hope someone has a idea.
> Regards
> Axel
