[GRASSLIST:7209] Compile Errors
Thomas Colson tom_colson at ncsu.edu
Fri Jun 17 09:47:28 EDT 2005
Any idea what could be causing this plethora of compile errors? Platform
is FC4 64 Bit, gdal version is 1.2.5, fftw is 2.1.5...
 ./configure --with-proj-includes=/usr/local/lib
--with-tcltk-includes=/usr/local/lib --without-postgres --with-freetype
--with-gdal --with-x --enable-largefile --enable-64bit --enable-w11
--with-opengl-libs=/usr/X11R6/lib64
--with-freetype-includes=/usr/include/freetype2 --with-blas --with-cxx
then make results in:
Following modules are missing the 'description.html' file in src code:
v.parallel
v.split
GRASS GIS compilation log
Started compilation: Fri Jun 17 09:32:05 EDT 2005
Errors in:
/grass6/lib/gmath
/grass6/lib/imagery
/grass6/lib/rst/interp_float
/grass6/display/drivers/XDRIVER/XDRIVER24
/grass6/display/d.mon/pgms
/grass6/imagery/i.class
/grass6/imagery/i.cluster
/grass6/imagery/i.gensig
/grass6/imagery/i.gensigset
/grass6/imagery/i.group
/grass6/imagery/i.his.rgb
/grass6/imagery/i.maxlik
/grass6/imagery/i.ortho.photo/libes
/grass6/imagery/i.ortho.photo/menu
/grass6/imagery/i.ortho.photo/photo.2image
/grass6/imagery/i.ortho.photo/photo.2target
/grass6/imagery/i.ortho.photo/photo.camera
/grass6/imagery/i.ortho.photo/photo.elev
/grass6/imagery/i.ortho.photo/photo.init
/grass6/imagery/i.ortho.photo/photo.rectify
/grass6/imagery/i.ortho.photo/photo.target
/grass6/imagery/i.points
/grass6/imagery/i.rectify
/grass6/imagery/i.rgb.his
/grass6/imagery/i.smap/shapiro
/grass6/imagery/i.target
/grass6/imagery/i.vpoints
/grass6/imagery/i.cca
/grass6/imagery/i.fft
/grass6/imagery/i.ifft
/grass6/imagery/i.pca
/grass6/imagery/i.zc
/grass6/ps/ps.map
/grass6/raster/r.param.scale
/grass6/raster/r.resamp.rst
/grass6/raster/r.in.gdal
/grass6/raster/r.surf.fractal
/grass6/raster/r.surf.gauss
/grass6/raster/r.surf.random
/grass6/raster/r.terraflow
/grass6/vector/v.kernel
/grass6/vector/v.surf.rst
Finished compilation: Fri Jun 17 09:32:34 EDT 2005
(In case of errors please change into the directory with error and run
'make')
cd lib
make
/usr/bin/ld: cannot find -lgrass_gmath
collect2: ld returned 1 exit status
cd rst
make
make[1]: *** [/grass6/dist./lib/libgrass_interpfl.6.1.cvs.so] Error 1
make[1]: Leaving directory `/grass6/lib/rst/interp_float'
cd raster
make
cd ps
make
/usr/bin/ld: cannot find -lgrass_I
make[1]: *** [/grass6/dist./bin/ps.map] Error 1
make[1]: Leaving directory `/grass6/ps/ps.map'
...and so forth.
What's frustrating...is I blew away the OS last night and
reformatted...thinking that I had a trashed OS install 'cuz I was getting
the same errors.....
grass source is latest from CVS.
