[GRASSLIST:7343] Re: Spearfish60=invalid mapset
Markus Neteler neteler at itc.it
Tue Jun 28 10:40:04 EDT 2005
On Mon, Jun 27, 2005 at 03:57:00PM +0200, s99171059 at tuks.co.za wrote:
> Dear reader
> Today I started the GRASS 6.0.0 tutorial.  I tried to load the Spearfish60
> mapset, but when I click on the PERMANENT mapset and clock 'Enter Grass', an
> error message pops up: 'invalid mapset'.  Any Ideas what I should do?
> Thank you
> Kobus Bedeker
The settings must as follows:
GRASS database: directory which *contains* spearfish60
Mapset:         preferably create your own using the right "create" field
You can select PERMANENT mapset if you own it. Otherwise you can
use data stored in this mapsets from any other mapset created and
owned by you.
Hope this helps
 Markus
