[GRASSLIST:7385] shapefile import problems
s99171059 at tuks.co.za s99171059 at tuks.co.za
Thu Jun 30 06:08:53 EDT 2005
Dear reader
I tried to import a shapefile using v.in.ogr.  Error:
v.in.ogr
dsn=/mnt/windows/werk/nuwe_projek/shape_CDs_ens/shape_files/cd3/2622/2622a
output=GrassVector6 min_area=0.0001 snap=-1
ERROR 1: Record count in .shp header is -12, which seems
unreasonable.  Assuming header is corrupt.
PROJ_INFO file not found for location Gauteng
PROJ_UNITS file not found for location Gauteng
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: 2622AB_INLAND_WATER_AREA_ALLFEATTYPES
DBMI-DBF driver error:
Column 'SOURCE_PRO' already exists (duplicate name)
Cannot create table.
Error in db_execute_immediate()
Cannot create table: create table GrassVector6_1 (cat integer, GDO_GID
integer, TAG varchar ( 50 ), FEAT_TYPE varchar ( 100 ), GEOM_TYPE varchar (
10 ), MAPSHEET varchar ( 20 ), ROW_STATUS varchar ( 1 ), LOCK_DATE integer,
SELECTION_ varchar ( 27 ), VERSION_NU double precision, VERSION_DA integer,
VERSION_ST varchar ( 1 ), MODIFIED_B varchar ( 15 ), RETIRED_DA integer,
ORIGINAL_G double precision, CREATE_DAT integer, DATA_SOURC varchar ( 50 ),
EST_REVISI integer, SOURCE_VER integer, SOURCE_PRO integer, SOURCE_PRO
integer, SOURCE_CON varchar ( 100 ), CAPTURE_IN integer, DESCRIPTIO varchar (
100 ))
Any ideas?
Kobus
