[GRASSLIST:6016] Re: How does one .. vector overlay/transparency
Sun Mar 6 03:25:08 EST 2005
> I'm creating a map of wind power for the the state of calif.
> d.vect -a map=wind_ca type=area display=shape
> so far so good (except I can't get rid if the border line)
as previous email, to get rid of line drawing:
d.vect -a color=none
> The last step I want to do is place political (state and
> county) borders on the map.
> I imported a shp of US state borders, but when I use it
> d.vect map=states
> it's areas are "filled", if I display this first, the data
> from wind_ca covers most of the border.
In the same fashion, set the fill color to "none":
d.vect map=states fcolor=none
another way with same result is to just draw vector boundaries, not
areas:
d.vect map=states type=boundary
This second method also avoids drawing the centroid markers.
Hamish
