[GRASSLIST:6061] Re: moving layers from one machine to another
Radim Blazek blazek at itc.it
Tue Mar 8 02:45:03 EST 2005
Sorry, ignore previous 2 mails (v.category and md5sum coor).
It fails when it is reading topo file, please try to:
1. run v.build on the file on Mac
2. check 'topo' file with md5sum on both platforms
Thanks
Radim
Chris Fonnesbeck wrote:
>>>>Chris, could you try to convert head and dbln files from UNIX to Mac
>>>>(newline characters)?
>>>Radim, I changed the line endings to Mac, but I still received a bus
>>>error on loading the layer.
>>>I also updated and rebuilt from cvs this afternoon, with the same result.
>>Does the error appeares with all vectors?
>>The vectors mooved from Mac to Linux work?
> I have never successfully imported this particular vector into Mac, as
> it takes way too long (see previous thread). I just tried moving a
> simple vector layer to Linux from Mac and got a segmentation fault.
>>Can you send here the end of debug (g.gisenv set=DEBUG=5 before module)?
> Here are the last several lines
> D3/5: dig_node_alloc_line(): add = 1
> D3/5: dig_Rd_P_node()
> D3/5: dig_Rd_P_line()
> D5/5:     line type  4 -> 8
> D5/5:     line type  -1 -> 0
> Bus error
