[GRASSLIST:6140] Creating Fedora Core 3 RPMS - problem at last stage...
caumann caumann at ualberta.ca
Sat Mar 12 23:30:26 EST 2005
So I modified the grass.spec file  (attached) that comes with the Suse RPM
available for download from the grass website.  Using this, grass compiles
fine on a Fedora Core 3 machine.  I can even create both the binary rpm and
source RPM files.  However, when I go to install the binary rpm, I get the
following error:
[root at michelangelo i386]# rpm -ivh --test grass-6.0.0-1.i386.rpm
error: Failed dependencies:
        libgrass_D.so is needed by grass-6.0.0-1.i386
        libgrass_I.so is needed by grass-6.0.0-1.i386
        libgrass_Iortho.so is needed by grass-6.0.0-1.i386
Which I find odd, because those libraries are all contained in the rpm file
itself:
root at michelangelo i386]# rpm -qpl grass-6.0.0-1.i386.rpm
/usr/local/grass-6.0.0/lib
/usr/local/grass-6.0.0/lib/libgrass_D.6.0.0.so
/usr/local/grass-6.0.0/lib/libgrass_D.so
/usr/local/grass-6.0.0/lib/libgrass_I.6.0.0.so
/usr/local/grass-6.0.0/lib/libgrass_I.so
/usr/local/grass-6.0.0/lib/libgrass_Iortho.6.0.0.so
/usr/local/grass-6.0.0/lib/libgrass_Iortho.so
So, what the hell have I done wrong?  I suspect something isn't set right in
the attached "spec" file, but I'll be damned if I can figure out what.
Any thoughts are appreciated.
Craig
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050312/9a6575a3/grass6.0.0.obj
