[GRASSLIST:6147] Re: r.in.gdal and HDF import
Sun Mar 13 18:30:08 EST 2005
[don't know; fwd -> grasslist]
Begin forwarded message:
Date: Sun, 13 Mar 2005 23:24:52 +0100
To: <hamish_nospam at yahoo.com>
Subject: SV: SV: [GRASSLIST:6142] r.in.gdal and HDF import
It's not listed there....
gdalinfo in the FWTools works well, but not within GRASS:
GRASS [/c/kart/sst] -> gdalinfo 199512h09ma-gdm.hdf
ERROR 4: `199512h09ma-gdm.hdf' not recognised as a supported file format.
GDALOpen failed - 4
Unfortunately, I'm too stupid to figure out this myself! : )
	-----Opprinnelig melding-----
	Fra: Hamish [mailto:hamish_nospam at yahoo.com]
	Sendt: su 13.03.2005 23:15
	Til: Tveraa, Torkild
	Kopi:
	Emne: Re: SV: [GRASSLIST:6142] r.in.gdal and HDF import
	> I've figured out that gdal supports HDF-files, but for some strange
	> reason my version of GRASS does not:
	really? try using -f to test from within grass:
	r.in.gdal -f input=test output=test | grep HDF
	If it is listed there, then you should have support, just need to figure
	out the correct format for the input string (not always obvious).
	(see Grit Schuster's email)
	what about trying to look at the HDF file with gdalinfo?
	Hamish
