[GRASSLIST:6179] GRASS vectors + Mapserver (was: PostGRASS in 5.7 tutorial ?)
Jean-Denis Giguere jdenisgiguere at fastmail.fm
Tue Mar 15 11:58:31 EST 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Markus Neteler wrote:
|>>Hi Jean-Denis,
|>>I have added this note on top of the old tutorial:
|>>NOTE: This tutorial is refering to GRASS 5.7. Meanwhile (2005), GRASS
6.0.0
|>>has been published. An updated (but unfortunately still incomplete)
version
|>>of this tutorial is available here: GRASS Six Tutorial.
|>>http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassSixTutorial
|>>I still have to migrate parts of the old tutorial into the Wiki.
|>>Answering your question: The direct PostGIS connection is no
|>>longer available. Once day, when OGR comes with a GRASS plugin
|>>for vector data, this will probably change.
|>>For now you can use v.in.ogr and v.out.ogr to directly exchange
|>>data with PostGIS. But it's an exchange, no real link into the DB.
|>It is possible to make the 'link' to any OGR layer (i.e. also PostGIS)
|>with v.external, but attributes with PostGIS work only if FID exists.
| right, but it's a read-only connection with v.external then.
Thanks for your answer !
It's quite sad because I saw the use of PostGRASS as a great way to
offer advanced spatial analysis within a Web portal using GRASS +
PostGIS + Mapserver.
Maybe the 6.x serie will offer interesting alternative !
Greetings,
Jean-Denis
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFCNxQ3mQkurNcFNt4RAtJLAJ9EHnhY3Z6qO85tULszch5IM07vMwCgmxbx
bpA2erN01qKWQ8ocwYQ2omQ=
=iCh6
-----END PGP SIGNATURE-----
