[GRASSLIST:6196] RE: display manager and monitors
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Mar 16 18:51:28 EST 2005
On Thu, 17 Mar 2005, Hamish wrote:
>> I use the graphical interface of Grass6.0.0 Cygwin stable (feb
>> something).
>> I have tried to import shapefiles into grass, and get messages like
>> this:
>> v.in.ogr dsn=/cygdrive/c/xxx/periode1a.shp output=p1a min_area=0.0001
>> snap=-1
>> PROJ_INFO file not found for location N50kart
>> PROJ_UNITS file not found for location N50kart
> what does 'g.proj -p' give?
> XY location?
>> Projection of input dataset and current location appear to match.
> ?! NULL == NULL ?
> can that ever be true for shapefiles? is .prj respected if it exists?
Yes... OGR reads the .prj file. If there is none there then OGR dataset
projection = 0 (XY) and if the same for location then the message about
projections matching will be (validly because XY == XY) reported.
I fixed v.in.ogr so it won't bother checking for proj_info and proj_units
if the location is XY and will avoid the confusing warnings.
Paul
