[GRASSLIST:6236] Re: GDAL install problems
Māris Nartišs maris.nartiss at gmail.com
Wed Mar 23 03:58:30 EST 2005
I found this bug some time a go - You cant build GRASS 6 w/o GDAL.
Building GRASS w/o GDAL always fails and there is a little sense to
build GRASS w/o GDAL.
IMHO GRASS developers should change GDAL from recomended to required package.
Whats Your distro and what problems You have with GDAL? I use GRASS
and GDAL on Gentoo and Slackware w/o problems.
wbr,
Maris.
On Tue, 22 Mar 2005 18:47:42 -0800, David Kramer <davidk at gmail.com> wrote:
> I'm trying to install GRASS 6.0 from the tarball. It seems to require
> GDAL, which I don't need. I can't install GDAL, due to problems with
> that distro, so I'd like to have GRASS not use GDAL. I pass
> with-gdal=no into configure, but I get this:
> checking whether to use GDAL... no
> checking for GDALOpen... no
> configure: error: *** Unable to locate GDAL library.
> Why does it want the GDAL library when it knows that it should not use
> GDAL? Any suggestions for hacks to get around this?
> Thx
> David
> P.S. If whoever maintains the GRASS mailing list home page is
> listening, the links off of it are pretty broken. For example, the
> using the search field gives an internal server error, the Google
> links pass you off to Google's regular homepage, and not a search of
> GRASS-Help etc.
