[GRASSLIST:6274] Re: v.in.ogr error
Kirk R. Wythers kwythers at umn.edu
Mon Mar 28 14:42:58 EST 2005
On Mar 28, 2005, at 1:05 PM, Moritz Lennert wrote:
> On Mon, March 28, 2005 20:55, Kirk R. Wythers said:
>> Thank you Moritz. I just stumbled to the fact that the help documents
>> on the web
>> (http://grass.itc.it/grass60/manuals/html60_user/v.in.ogr.html) are
>> more detailed (including additional information concerning v.in.ogr
>> options) than those that are generated from the build and install
>> process. I will look on the web in the future.
> This is weird. I have exactly the same manual page locally as the one
> on the
> web. Maybe there was some error building the docs on your machine ?
If there was, there is nothing in the error.log
> Moritz
>> Kirk
>> On Mar 28, 2005, at 12:14 PM, Moritz Lennert wrote:
>>> On Mon, March 28, 2005 19:23, Kirk R. Wythers said:
>>>> What is implied by the error:
>>>> GRASS 6.0.0 (arrowhead_utm):~ > v.in.ogr -o
>>>> dsn=/Users/kirkw/projects/wrf/grids/ layer=forties output=forties
>>>> Over-riding projection check.
>>>> Proceeding with import...
>>>> Layer: forties
>>>> DBMI-DBF driver error:
>>>> Column 'PLS_FORTYP' already exists (duplicate name)
>>>> Cannot create table.
>>>> Error in db_execute_immediate()
>>>> ERROR: Cannot create table: create table forties_grid (cat integer,
>>>> AREA
>>>>         double precision, PERIMETER double precision, PLS_FORTYP
>>>> integer,
>>>>         PLS_FORTYP integer, COUN integer, TOWN integer, RDIR
>>>> integer,
>>>> RANG
>>>>         integer, SECT integer, FORT integer, GLOT integer, PARC
>>>> integer,
>>>>         FORT_DESC varchar ( 40 ), GLOTMATCH integer, GEOPARC
>>>> integer,
>>>>         GEOGLOT integer, GEOFORT integer, GEOSECT integer, GEORANG
>>>> integer,
>>>>         HECTARES double precision)
>>> The problem is that your dbf file contains two columns with exactly
>>> the same
>>> name (PLS_FORTYP) which is unacceptable for the database driver.
>>> Change one of
>>> the column names in the table before using v.in.ogr or use the cnames
>>> option
>>> of v.in.ogr.
>>> Moritz
>>>> I am trying to import some shape files into utm location in
>>>> grass6.0.
>>>> The shape files have the naming scheme:
>>>> forties.dbf
>>>> forties.sbn
>>>> forties.sbx
>>>> forties.shp
>>>> forties.shx
>>>> Thanks,
>>>> Kirk
