[GRASSLIST:6287] INSTALLATION PROBLEM
Massimiliano Cannata massimiliano.cannata at supsi.ch
Wed Mar 30 03:49:43 EST 2005
Hi, can anyone help me?
I cannot get any response ar idea about what is going wrong......
Here is the compilation log and as you can see I get no errors....
GRASS GIS compilation log
Started compilation: Wed Mar 30 10:03:08 CEST 2005
Errors in:
Finished compilation: Wed Mar 30 10:10:09 CEST 2005
(In case of errors please change into the directory with error and run
'make')
It seems that I get error in reading region...
by using the same WIND file on my laptop (whare i successfully install
GRASS-6.0.0) and on the server it gives me always the same error.......
GRASS 6.0.0 (test1):/usr/local/src/grass-6.0.0 > g.region -p
ERROR: default region is invalid
       line 11: <top: 1>
her ethe WIND file:
proj:       99
zone:       0
north:      177846.30208341
south:      56014.58333336
east:       744765.89285719
west:       647731.25000004
cols:       970
rows:       1218
e-w resol:  100.03571429
n-s resol:  100.02604167
top:        1
bottom:     0
cols3:      970
rows3:      1218
depths:     1
e-w resol3: 100.03571429
n-s resol3: 100.02604167
t-b resol:  1
What can I try to meke grass working?
Thanks
-------- Original Message --------
Subject: 	[GRASSLIST:6248] segmentation fault after installation...
Date: 	Thu, 24 Mar 2005 17:11:35 +0100
From: 	Massimiliano Cannata <massimiliano.cannata at supsi.ch>
To: 	grass <GRASSLIST at baylor.edu>
Hi, I'm trying to install grass-6.0 on on a Dell PowerEdge 2850,
installed with RedHat ES3, Update 3.
I successfully run ./configure
(CFLAGS="-g -Wall" ./configure
--with-postgres-includes=/usr/include/pgsql/server/ --with-motif
--without-blas --without-lapack --with-glw --with-dbm
--with-dbm-includes=/usr/include/gdbm --with-freetype
--with-freetype-includes=/usr/include/freetype2/ --without-readline
--without-fftw --with-proj --with-proj-libs=/usr/local/lib --with-cxx)
I successfully run make
and I can start (grassbin.i686-pc-linux-gnu/grass60) and define a mapset
and location.......
But most of the general command return a segmentation fault error.....
GRASS 6.0.0 (hydro3):/usr/local/src/grass-6.0.0 > g.region -p
       line 11: <top: 1>
GRASS 6.0.0 (hydro3):/usr/local/src/grass-6.0.0 > g.list rast
Segmentation fault
GRASS 6.0.0 (hydro3):/usr/local/src/grass-6.0.0 > r.mapcalc 'test=99'
 100%
GRASS 6.0.0 (hydro3):/usr/local/src/grass-6.0.0 > r.out.ascii input=test
output=/home/maxi/test.txt
GRASS 6.0.0 (hydro3):/usr/local/src/grass-6.0.0 > more /home/maxi/test.txt
north: 10
south: 0
east: 10
west: 0
rows: 10
cols: 10
99 99 99 99 99 99 99 99 99 99
Segmentation fault
GRASS 6.0.0 (hydro3):/usr/local/src/grass-6.0.0 > g.list --help
Usage:
 g.listSegmentation fault
I can also see that the general commands doesn't have the
option->description="The type of query" ;
changed to
option->description=-("The type of query" );
could it be the problem?
Any suggestion for resolve the problem is very very welcome......
Thanks,
Maxi
_____________________________________________________
Ing. Massimiliano Cannata
SUPSI - Istituto Scienze della Terra
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 (0)91 935 12 25 - Fax +41 (0)91 935 12 09
mailto:massimiliano.cannata at supsi.ch
http://www.ist.supsi.ch
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050330/1bee766c/attachment.html
