[GRASSLIST:6292] Re: GPS points off by about 120m to the west
Dylan Beaudette dylan at iici.no-ip.org
Wed Mar 30 11:32:15 EST 2005
On Mar 29, 2005, at 11:58 PM, Hamish wrote:
>> after retrieving some waypoints from my Garmin 12 GPS, i noticed that
>> when  imported into GRASS, they were offset by about 120 meters to the
>> west....!
>> here is a picture of the bad (red) points, and corrected (blue)
>> points: http://basho/~dylan/temp/bad_gps.png
>> i am nearly positive that the data in GRASS is good: in NAD83/WGS80
>> UTM zone  10N projection.
>> the GPS was set for the same projection parameters...
>> any ideas on what could have caused this 120meter shift to the west?
>> could my GPS really be in a NAD27 datum, and still be reporting NAD83
> The GPS is exporting waypoints in WGS84;
> the error you are seeing is surely due to a datum shift;
> v.in.garmin should take care of all that for you.
> i.e. regardless of what you have the GPS datum set to display on the
> screen, it will output WGS84. At least that what my Garmins do.
> were you importing with v.in.garmin or v.in.ascii?
> note v.in.garmin in 6.0 is broken, get the latest version of the script
> from CVS.
> Hamish
Hamish and others who replied,
thanks for the information on this -- i was using v.in.ascii to import
these points ... thinking that the GPS would be exporting my points in
NAD83/UTM as the GPS unit was configured to use. i will give it a try
with the CVS copy of v.in.garmin a little later this week.
on a related note, if i am sending points to the GPS- they would need
to be transformed to WGS84 as well?
maybe cs2cs can do this for me?
thanks!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
