[GRASSLIST:6305] Re: r.terraflow
Māris Nartišs maris.nartiss at gmail.com
Thu Mar 31 05:28:31 EST 2005
if I have a C++ compiler, will configure detect it and compile with
C++ or I have to force it with --with-cxx flag?
Documentation for Grass 6.0 r.terraflow does not say anything about
requirement to compile Grass with cxx support to enable terraflow.
There should be a note about this. Currently note is only in
requirements list, but link (Installation requirements (needed
libraries)) in download page (http://grass.itc.it/download/index.php)
still points to 5.4 versions requirements list and there is no info
about C++.
How often users have C compiler and no C++ compiler? Most Linux
distros ship with both compilers (gcc and g++) or no compiler at all.
Just my 2c.
Maris.
On Thu, 31 Mar 2005 12:18:54 +1200, Hamish <hamish_nospam at yahoo.com> wrote:
> > r.terraflow bid is in C++, thus you have to ./configure --with-cxx
> > (which is  not obvious by any means, right).
> > I guess the switch should be forced by default, as r.terraflow is a
> > Grass  element.
> I'd say no. A C++ compiler is not standard item and should not be a
> required prerequisite. Configure should work by default and let you
> turn extra things on, not fail until you switch things off. I'd rather
> get "how do I get r.terraflow" emails than "can't get past configure"
> emails.
> Also r.terraflow is still waiting on security fixes that the rest of
> GRASS already has.
> Of course r.terraflow is a major plus for GRASS.
> Hamish
