[GRASSLIST:6788] neighbors of polygons
    Daniel Isenegger
    disen at geo.unizh.ch
    Mon May 16 06:59:07 EDT 2005
i work with grass 5.7 having the attribute data in postgres-DB.
in a polygon-shapefile containing several hundred of polygons i want to
analyze for each polygon which neighboring polygons it has. Conceptually
i see there 2 cases:
1) neighboring polygons sharing a common boundary with the current
polygon: these polygons should be selectable by identifying the
identifiers of the border-lines of the current polygon and search over
all border-lines of all polygons for those identifiers.
here my question is: how to identify the identifiers of all border-lines
of a polygon?
2) neighboring polygons not sharing a border with the current polygon:
here i thought of creating buffers with increasing sizes around the
current polygon and looking for
- easy case: centers of other polygons located within these buffers
- computationally more challenging case: arbitrary point of a polygon
here my questions: this method is not very elegant (conceptual and
technical). do you have better ideas for solving a problem like this
Many thanks
dani
ps i tried to do an approach to do this with v.to.db, but didn't
progress much
