[GRASSLIST:8833] Re: Editing attribute tables for internal GRASS db
Wolf Bergenheim wolf+grass at bergenheim.net
Tue Nov 1 17:47:55 EST 2005
The internal tables are in dBase format. Which means you can open them
using openoffice or microsoft office, etc. The files are located in
/path/to/grass/db/location/mapset/dbf.
--Wolf
On 02/11/05 00:24, Jason Horn wrote:
> Is there any way to edit the attribute tables for a vector layer if  you
> are using the default internal GRASS db?  I know that I can set  the
> database to an external mySQL db (for example), and then use a  mySQL db
> tool to edit the tables.  Is there any way to do it for the  internal
> GRASS db?
> Thanks,
> - Jason
<:3 )---- Wolf Bergenheim ----( 8:>
