[GRASSLIST:8834] Re: Editing attribute tables for internal GRASS db
Hamish
hamish_nospam at yahoo.com
Tue Nov 1 17:53:56 EST 2005
> Is there any way to edit the attribute tables for a vector layer if
> you are using the default internal GRASS db? I know that I can set
> the database to an external mySQL db (for example), and then use a
> mySQL db tool to edit the tables. Is there any way to do it for the
> internal GRASS db?
(ie default dbf driver?)
Interactive:
d.what.vect -e
v.digit?
qgis with grass plugin?
Script:
db.execute
see the example in the help page:
http://grass.ibiblio.org/grass61/manuals/html61_user/db.execute.html
Small tables: (caution, make a backup)
load into OpenOffice or any software that can handle the dbf format.
Hamish
