[GRASSLIST:8878] Re: photo.camera: How to make? My binary is missing!
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Fri Nov 4 04:36:12 EST 2005
Markus, indeed I found them there too, heh. Oops. I guess I forgot
that you can just enter a new name at the prompt. The prompt looks the
same as picking a datum from a list, so I thought you would have to
pick an existing file. My mistake. Seems to be working fine.
-Ian
On Nov 4, 2005, at 1:11 AM, Markus Neteler wrote:
> The photo.* commands are sitting in
> cd $GISBASE/etc/photo.*
> at least they should and they do so on my Linux box.
> Markus
> On Thu, Nov 03, 2005 at 11:57:59PM -0800, Ian MacMillan wrote:
>> Phillip, I have found the same issue with my version of GRASS (OSX).
>> I have looked in both my 6.0 source bin directory and in my 6.1cvs
>> (Oct. 22 source) bin directory. No photo commands in either version.
>> My binaries came from Lorenzo's page. I have looked at the source for
>> 6.0 and 6.1cvs and noticed that the photo commands are present there
>> (under i.ortho.photo), but I am not sure why they aren't sent with the
>> binaries. Specifically it looks like the mod_cam_info.c command
>> doesn't get included.
>> I don't know that I am savvy enough (or have the time to get myself to
>> that point) to fix this myself. Any developers have some insight?
>> -Ian
>>> Hi all,
>>> I am trying to ortho-rectify some photographs and have a problem.
>>> The
>>> program "photo.camera" doesn't exist in my Cygwin installation (
>>> grass6.1.cvs-i686-pc-cygwin-02_09_2005) that I downloaded off the
>>> net.
>>> I am running i.ortho.photo and have run through steps 1-3 and now
>>> on the
>>> 4th step I need to select the camera file. I only have the option
>>> to
>>> list existing camera files and I have none. I have tried to run
>>> the
>>> photo.camera program but it doesn't exist. Actually none of the
>>> photo.*
>>> commands appear to exist on my system. Was there a problem when
>>> this
>>> binary was compiled?
>>> If the camera file is ASCII can I build it by hand? If so what's
>>> the
>>> format?
>>> Thanks,
>>> Phillip Allen
>>> e-mail: paallen at attglobal.net
> Markus Neteler <neteler itc it> http://mpa.itc.it
> ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18 - 38050 Povo (Trento), Italy
What happens if a big asteroid hits Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad.
- Dave Barry
This message has been scanned by Postini anti-virus software.
